The engine won't "pop" with starter fluid squirted into the head space. I measured the compression and it was below 50psi. Looks like a valve problem. Does anyone have any idea what the compression should be? How difficult is it to replace a valve?
100 or better, 90 being ok, other things besides a valve would be... a head gasket leak, its not getting spark to even ignite the fuel, or the plug is fouled, maybe a sheared flywheel key,( it'll give spark but will be off timing ). that or maybe the valve, but a bad sealing valve. did it just start doing this?
It had been getting progressively harder and harder to start. During the last operation it shut down upon running out of fuel. I didn't run it for 2 weeks then I found the problem when I tried to start it. I replaced the plug with a new plug, cleaned the fuel tank and cleaned the carb. The pressure washer pump connected to the engine rotates when I turn the engine over in attempts to start it. The plug does spark when held against the case as I rotate the engine. Compression is actually closer to 25psi.
I just had a NO compression with GCV190. Tried brake cleaner in carby and cylinder , thru plug hole.. Replaced the plug and after a series of cord pulls,still no luck. I then emptied oil and took valve cover off and found inlet valve STUCK fully open. Lucky spring tension is minimal , so manually compressed spring and removed. Pliers on top of valve stem and pulling freed valve. Sprayed some lube on it and it then moved easily.Very briefly ( 1 sec ) engine run, without oil,cause need a new valve cover....which are hard to find.
Don’t forget there is decompression valve and your reading will not indicate correct on just turning motor.
