I have a Homelite UT20006 Weed wacker. It cranks up fine when in full choke, but if I put it in half choke it dies. What is wrong with it? How do I fix it?
Sounds like the carburetor needs a cleaning/new diaphragms and gaskets. Look at the carb and locate #'s stamped on it. This will help us help you find a rebuild kit. Are you comfortable rebuilding the carb?
As I was disassembling, the fuel line pulled into. Granted I the tank was dangling, but it should not had broke in two. So now I am wondering if the fuel line was already torn or something. I am gonna replace the fuel line Monday and see if that makes a difference. If not I'll get the carb number as you previously suggested. Thanks!
