1 - 3 of 3 Posts
I can't find anything on the web with help. My ESC is a GM Racing SX12
I can't seem to get the brake working. I went to reset the ESC but now everytime I go to reset it the brake will not work. Any suggestions. I think this ESC is way to advanced for me. I was reading an article that said you can connect this ESC to your Computer and program it. If anyone has any info it would be greatly appreciated.
Thank you
try contacting horizon hobbies they make it. I have a GM V8. The setup should be automatic just press and hold the setup button till it blinks then pull the throttle all the way then the brake. did you make sure the radio dosn't have the brakes dialed out?
Thank you
try turning the brake up on your radio, if you can
just a idea, hope it helps
CDW
1 - 3 of 3 Posts
