Hello, I am a retired auto mechanic..
working on a Toro Wheel Horse 8-32
B&S 8 hp.
191707 6021 01 90021710
if jump the selinoid it will run... but putting it in gear will kill engine..
here is part of the issue this unit came with NO battery and starter selinoid is missing... and possible wires maybe missing...
I installed battery and universal solenoid... there is no power to key switch wires.
and everything I have tried to disable safety circuits do not work
does Toro use an Isolated ground starter solenoid???
this is a freebee for a church member.. all help is welcomed.
Discussion Starter · #2 ·
just so.. EVERYONE knows.. I believe in all safety circuits MUST work before the unit is returned to a customer....
regardless what I do .. I can not bypass the transmission safety switch.... engine does run... if I try to go to Reverse OR any forward gear the engine dies.... YES I could remove the magneto kill wire.. but I like to stop the engine without a screwdriver.
based on the provided wiring diagram... NO Positive power goes to the key switch.. so solenoid must be a negative driven type.
and as far as I can tell.. the battery negative is NOT connected to the body ground. (floating Ground ) and (floating Negative).
If the illustration is representative of your wiring setup, then the issue is likely the safety interlock module (listed in the diagram as module). It's probably bad and causing the engine to die when any of the switches are activated.
Discussion Starter · #4 ·
the diagram is from the owner manual for this tractor..so owner said.
will try to locate the Module and a correct starter solenoid.
and fix several cut wires and a few burnt connectors.
I Thank You for your help AGAIN.....
