my dad and i have tried hitting it with a hammer and tried heating it up with a gas welder until red hot and it will not come off it is the plate that mounts the blade , i tried using oil and lubricant but the plate will not come off either any ideas anybody????
you are talking about the blade block. most of the time when they are stuck that bad we cut them off . take an cut the side of the block up an down BUT do not cut to deep because you dont want to hit the crank. then take a chisel an beet it off.
Discussion Starter · #4 ·
hi
yes ive got it off now it turned out we had 2 just cut the plate and we are now left with just the pipe part still on the shaft but thats ok:) i can get it off now if i want to:) i cldnt get a saw to fit i there or a grinder so ive taken the plate off which then allowed me to remove the exhaust and engine mounting bracket which is what i need thanks for your help:D
