1 - 20 of 46 Posts
BANNED
FALL OUT
Saturday OCTOBER 27 2012
Classes:
1) TJ/PS Pro Stock t-jet- (formerly TJ/S t-jet stock) original copper bottom chassis. Stock 16 ohm unbalanced arms only. Narrow double flanged wheels (plastic, brass, aluminum, or steel) and stock width slip on silicone tires allowed. Original copper pickup shoes and pickup shoe springs. NO braids or shunts. Wheelie bars allowed. Hard plastic injection molded and resin cast, screw mounted bodies allowed. NO vacuum formed, cardboard or paper bodies. Minimum weight 18 grams. Maximum weight 22 grams
2) TJ/M t-jet modified- Modifications are 5.5 ohm armature. Any ceramic magnet allowed. One traction magnet, any motor brushes, any gears, any wheel and tire combination. Weighted front wheels allowed No braids or shunts. Copper or silver chassis allowed. "NO QUADS"'. Now including Johnny Lightning and Auto World Ultra-G chassis. Minimum Weight 20 grams. Maximum Weight 25 grams
3) AFX/S AFX & MagnaTraction Stock- armature, per (i.e. 14.5-ohm for magna-traction, 5.5 ohm for non-magna-traction). Slip on silicone tires of stock diameter. O-rings may be substituted for front tires. Stock magnets according to specific chassis. Johnny Lightning and Auto World cars allowed. Ultra-Gs permitted with traction magnets removed. Minimum weight 20 grams. Maximum weight 25 grams
4) AFX/M A/FX modified- 5.5 ohm armature allowed. Any ceramic magnet allowed.. One (1) traction magnet, any motor brushes, gears, wheels and tires. No braids or shunts. UltraG chassis allowed. Minimum weight 21 grams.
5) 4G/S+D Specialty/4-Gear Stock and Dragster- Stock armature and magnets per chassis. Slip on silicone tires. Auto World chassis allowed with traction magnets REMOVED. Minimum weight 21 grams. Max weight 26 grams.
6) P/PM Pancake Pro Mod- Any chassis that has 3 or 4 gears on top plate allowed. Any armature allowed that ohms no lower than 3.5 ohms. Polymer motor magnets allowed. Pickup shoe braids & shunts allowed. Traction magnets allowed, max of two (2). Any motor brushes, gears, wheels and tires allowed. Any plastic body allowed. All other mods Ok. Minimum weight 21 grams.
7) I/S Inline Stock- This includes any inline car readily available with a stock motor, magnets and gearing. Slip on silicone tires allowed. Tyco, Tomy, AFX, Lifelike, etc. NO Wizzard or SlotTech cars. Minimum weight 18 grams
8) D/S Door Slammer- 5.5 ohm armature allowed (hot- stock motor). Polymer & baked NEO motor magnets, pickup shoe braids allowed. Shunts allowed. Any motor brushes, gears, wheels and tires. DIE CAST BODY. minimum of 57 grams.
BLUE COMET MC
4042 Mensch Road, Skippack, PA. 19473
Doors open 8 am Qualifying at 11 am
1/64 scale 1/4 mile 32' overall length, WIZZARD drag strip
TJ/PS body must be hard plastic and mount using original mounting screw holes in chassis.
other classes may use resin cast and hard plastic bodies that are securely mounted to chassis.​
What! Over 3 month away:confused:
Help I need a racing fix!!!:p
Well I suppose I need to finish up a couple cars yet and I can wear out my currently running cars till then and rebuild them.:thumbsup:
I am very much looking forward to this:woohoo:
BANNED
Discussion Starter · #18 ·
not this time, but I will be taking a poll to help determine classes for the next race.
I don't want to try more than 8 classes in a day and we have to disappoint someone by doing that. sorry.
1 - 20 of 46 Posts
