Hi Ya'll again. I need help !!!
I am working on a (automatic) lawn tractor & do'nt have any idea where to start. I sit,press clutch, turn key & engine runs. The tractor will not go into gear (forward or reverse) when eather peddle is depressed. The netural rod
is pushed in. Do I need to look for a fuse or safty switch?
THANKS, willie
Almost sounds to me like your linkage might have came loose. Where the pedal control goes for forwad and reverse, check all your linkages and make sure your linkages are working and not slipping. Follow it back to your transmission, make sure nothing is slipping. I dont believe its a safety or fuse because your engine starts and runs. See if I can attach a file for ya. Cross your fingers.
(ah-ah) I found the problem. The automatic transmission belt broke into
because one idler pulley's froze up. I have replaced both & now will try
& rehook the idler tension spring. HELP ???
