I have been running a Novak 6.5 system in my Losi xxxt and it has run great, but lately it has been shuttering when ever I get on the throttle hard or accelerate up a jump. One of the sensor wires was loose so I put a brushed motor in and it did the same thing. Could the cap be causing the problems? It does have a couple dents in it.
Thanks,
David
Cola, sounds as if the GTB has had a hard life. You might be better off just sending it back to Novak to have it checked out. There service is awsome and fast.
Service awesome and fast.....YEAH RIGHT!!!!
I sent my GTB in before the BIRDS and still haven't recieved a box from them.....:mad:
Check out the wires on the switch. I had the same problem and found that a wire on the switch was broke. I replaced the switch and the problem was solved.
Discussion Starter · #6 ·
Thanks for the reply's. I found out that it was a fired rotor, and I needed to run a cap on my spektrum.
Thanks,
David
