have no spark. the air gap is set at .010. magnetics good. how can i check the coil
N ndhp82a · Registered Joined Sep 24, 2009 · 1 Posts Discussion Starter · #1 · Sep 24, 2009 Only show this user have no spark. the air gap is set at .010. magnetics good. how can i check the coil
P pyro_maniac69 · Registered Joined Aug 12, 2007 · 814 Posts #2 · Sep 26, 2009 Only show this user if the air gap is right, and you still don't have spark even with the shut off wire is unhooked, you need a new coil
