the thing will start, but will only run if I continue to pump the primer. I suspect a bad vacuum line. What could the other problems be? any help would be appreciated.
thanks
thanks
Post the model number for the mower and the engine so we know what you have. Have a good one. Geothe thing will start, but will only run if I continue to pump the primer. I suspect a bad vacuum line. What could the other problems be? any help would be appreciated.
thanks
