Hey Gang,
I thought I'd share my latest Auto Parts store find...
It's a 9" LED strip under the OPTX brand made by streetgow (www.streetglow.com)
I know, nothing new so far... I was originally looking for trek lighting but these (they come two to a pack) just happen to be the perfect solution for you Millineum Falcon builders out there because the strip is the right length, is bendable (to a point, you can't fold it ), is a bright blue and is already designed to run on 12v with no other wiring needed ('sept power and a switch)
I thought about the down side of LED strips - namely the uneven light coverage - but if you are putting this in the Fine Molds Falcon like I did, the "grill" piece breaks up the light anyway and hides the bright spots. here are some pics. taken with and without room lighting.
I put foil tape inside the "engine box" they give you but I didn't include any of the other engine pieces. I also added a frosted piece of really thin clear styrene right behind the grill to further diffuse the light.
the ship still has a way to go yet, but I thought some of you might want to know about this easy way to get a really nice engine effect
