Yea, more info please, I have a 3PMX and have tried for a year to get dual rate overide to work>>>
I have found the 2nd condition but not how to get it to interact with the dual rate..
Hold select button down and turn on remote
Set "SW1-CD"
Set "DT3-OF"
Set "CON D2" to "on"
Turn radio off
Turn radio back on NOT holding select button
Set "EPA ST" both directions to "100%" (or max before servo starts whining)
Set "DYR-ST" to "40%" (or your normal limited steering %)
I think that is all I had to change...
When finished you should have 40% steering, press the SW1 Button (on the grip) and you should get flashing blue light, cond2 on display and 100% steering, press SW1 again and you should be back to 40% steering.
Hope this helps!!
