You can use the old a arms.Use rpm ball cups take a 1/8 drill bit and open up the rpm ends a bit.Pan Car Front end w/ B3 Kingpins and short upper arms
What's needed, got images??
(Using old school Associated front end)
Dialed :thumbsup:You can use the old a arms.Use rpm ball cups take a 1/8 drill bit and open up the rpm ends a bit.
You will need the ksg machined steering blocks or hyperdrive cut down steering blocks.
Jake
The short of it is it is way easy to build and keep smooth a lot less parts to rub bind ect.What is the benefit to switching.to.the ball cups and.does it affect your current setup
I use 1500 and wet sand them just a bit then use polishing compound I just chuck up the king pin in a drill.hey guy i have a Q. when you are polishing your kingpins do you sand them down first and if so what grit do you use. also do you put any thing on the king pin, and if so what kind and how much. any help is very much appreciated :thumbsup:
Take a look at my truck here the next week or so. It is the way to go. Super smooth with no slop.What is the benefit to switching.to.the ball cups and.does it affect your current setup
Joe, why don't you just come to the best guys on the west coast and one the best in the nation and ask for help. We can show you exactly what you need to do and how to do it. Pretty simple. You have the best oval facility this side the Mississippi, come over, ask for help or pointers and we'll get you going. Simple...:wave::wave::wave::wave::wave::wave:
You will change it just to slow me down lol see ya soon bradTake a look at my truck here the next week or so. It is the way to go. Super smooth with no slop.
No if it sticks and is not free take a pair of plyers and smash the ball cup make sure it is on the king pin do the same thing to all the ball studs on the steering if you are using ball studs.do you put lube on the upper ball on the b3 kingpin?
