Hey All,
Appologies for the rambling...
I haven't got much experience fixing engines but i got ahold of a freebie from my buddy recently and i'm trying to get it going. No luck so far. Throughout all the efforts below, almost the exact same symptom: Pull on the starter cord and it won't start... doesn't even come close. The gas is maybe 4+ months old, but my mower is running on the same stuff and i believe i put stabalizer in the can after i filled up at the gas station.
It's a Sears powerwasher with a Briggs and Stratton... i'll have to look for a model number when i get home. Only specs i have on hand are:
Bore 2.69in, Stroke 2.04in, Displacement 11.57in3/190cc
I think the iniitial problem was that he cross-threaded the spark plug during a tune-up. He used a thread-saver but didn't remove the head, so all the tapping shavings ended up in the cylinder. I'm unclear how much time he spent trying to start it after the shavings were floating around in there. Sears quoted him a ton of money to fix it so he just bought a new one.
I took the head off and cleaned the shavings out with compressed air. I was expecting to see a huge mess with scratches and nastiness along the cylinder but it looked "good to me"... which means nothing since i'm not experience. But still wouldn't start after cleanout and re-assembly.
Next i noticed that the spark plug wouldn't tighten all the way down. I took out the plug and the saver-threads came out with it. So i re-tapped the threads with a new saver kit... i don't think the first saver-thread-sleeve was inserted deep enough. Reassemble, plug looks snug, still won't start.
For kicks i check the model number on the plug - it's an autolite (i think?) but i can't find anything online to indicate that it's compatible with the recommended plug for the engine (which is B&S 491055S). So i grab a suitable Champion replacement plug at HD. Sadly, taking out the old plug now rips out *my* thread-saver. Tapping a 3rd time didn't go smoothly - hole was too large for 3rd saver-sleeve. Last resort, i coated a sleeve with JB Weld and put it in. Next day - pretty good result. Seems solid. Pop in the new Champion plug, seems snug... still nothing.
I was considering buying a cheap compression tester from Harbor Freight but read some scarry reviews that said they are garbage. I cannot invest too much more money into this project ... diminishing returns and all. This thing might end up in the junk pile shortly. Hope you guys can recommend something.
Other info:
I thought i saw some smoke puffs coming out the intake when i was trying to start it. I read this is a symptom of over-filled oil. Indeed... my oil level was high, so i emptied some. Still feel like i see a little bit of a puff out of the intake, but it was getting dark when i was testing last and i was punchy by then. If puffs are coming out the intake, is this engine done?
I took apart the block to see if shaving made it past the piston (and, i admit, also because i was curious what it looked like in there). Didn't see any shavings or obvious damage. When re-assembling, i wasn't quite sure how close the magneto is supposed to go to the flywheel. There is maybe 1/8" (or less) play when mounting it. Currently i have it 'far' from the flywheel because i didn't want to risk rubbing, but that was guesswork. Should it be 'close as possible'? I tried measuring the voltage generated by the magneto with a volt meter but couldn't get meaningful measurements and have no idea what they're supposed to be anyhow. Grasping at straws at this point.
The paper gasket got pretty much wrecked when i openned the block. I hadn't thought about that before opening it. When reassembling i used some copper-high-temp gasket paste (silicon something?) to try to augment the sloppy gasket. I just wanted it to hold well enough so i could see if the engine would run.. then i could get a new gasket and fix it right. Would there be so much leakage due to that gasket mess that i wouldn't even get it to start at all?
The push rods fit very tight against the rocker arms (or whatever they're called). I thought there was supposed to be some gap.. but i'm pretty sure they were like that before i did any messing around.
Anyway... if i'm overlooking something very simple that i should try, i'd appreciate any feedback. Also curious what the cheapest (yet still effective) compression tester is...
Thanks a lot,
Joe
Other info:
Thanks a lot,
Joe
