I think someone posted this awhile back but it's good to have it posted again and with a nice review.......:thumbsup: Great price for a sound option that most in the forum would have no problem working with. I'd like to offer a bit of advice, pull the label off the speaker that came with the card and see how many ohms it is, that will give you a benchmark for how much of a load your added speakers should be. Right now you have yours in parallel so if they are 8 ohms each, your load on the card's amp is 4 ohms, if 4 ohms each that's 2 ohms. I point this out to keep you from blowing out the amp by overloading it's output. It's not the number of speakers that's important, it's the total resistance you need to be mindful of.
The two pads you showed look like they had a diode across them, that's a common way to protect against reverse polarity mistakes, so you may be right as to them being power inputs. But what voltage is required ? Just because you have 4.5 volts in battery power doesn't mean that's what you'd apply to these pads. Is there a regulator stepping down the voltage of the batteries?????
