1 - 1 of 1 Posts
From Exotek come this Pro style alloy rear hub set with vertical ball link mounting for the SC10 4×4. Vertical ball stud mounting allows for quick and precise roll center changes. Simply use 3mm metal washers or shims to raise or lower the ball height. Precision machined from T6 alloy for precise fit, lightweight design and heavy duty use, they use the stock bearings and maintains the stock toe geometry.
Source: Exotek [exotekracing.com]
More...
1 - 1 of 1 Posts
