Hi. New to your forum, and need some guidance. I have an Echo SRM 260 weed eater. I let it sit with gas / oil mix in it for about 10 weeks. Ran fine when used last. Today, I went to fire it up. It starts, will idle a little bit, but will not gain RPM's when I press accelerator lever. Bogs out. If I shut choke off, it will idle, but when I press accelerator, it dies. Dumped out old gas, went and bought fresh gas / oil mix. No change. Removed air cleaner and carb, sprayed everything I could see, put in back together, no change. Took it back a part, went deeper into the carb, using spray can carb cleaner on everything I could see. Re-assembled, no change. Seafoam in the tank to assist in clean out. No change. Sprayed carb cleaner around intake area while at idle, no change. Pulled muffler off and started. No change. Spark plug looks good, no buildup. Any ideas?
And thanks in advance for your time and patience!
