is it broken?...............chances are that you can oil it and git it to work if the hook on it isnt broken..............hellova lot easier than replacing
Not broken, will try oil first.
Will let you know if that corrects it. It was under water and not used for a long while.
Bill
So what is the problem? The string doesn't recoil? The starter dogs may be stuck, some WD-40 or a good penetrating oil should free them up. (Starter dogs are small fingers that the starter latches onto when the rope is pulled).
under water?...........do yourself a favor and trash it, you will be chasin gremlins untill you have replaced nearly everything, save the money for parts and tylenol and go git a new one
