Is there an easier way to unstick a stuck ring on a 2 cycle engine than disassembling the engine? I just did this to a Poulan BVM200VS leaf blower that wouldn't start and I couldn't get over 60 lbs. of compression, Now it's starting in 2 pulls. Not sure if I had to do all that I did? I did find some scoring on both the piston and the cylinder.. I used a fine steel wool pad on both of them. I soaked the piston and ring in gasoline and then carefully removed and cleaned the ring with steel wool. I'm happy with the outcome...just wondering if there is a quicker or easier way that anyone uses. Is using steel wool on minor scoring a good idea...or am I removing a coating that I shouldn't?
Spit
Spit
