1 - 1 of 1 Posts
The new 1/8 scale from Duratrax, the 835B is loaded with Stress-Tech parts, and every one of them is protected by a 1-year replacement guarantee. If any Stress-Tech part fails during the first year, DuraTrax replaces it free. Other reasons for the 835’s durability include grey-anodized aluminium parts and hardened steel parts in the drivetrain. Driving the 835B is a SuperTigre G-27CX .27 engine, known for dependability and power, and it’s protected by a 3-year limited warranty. For control Duratrax provides a 2.4GHz FTR (Futaba Transmitter-Ready) system. It’s several steps above the usual ready-to-run radio, because it includes digital, metal-geared steering servo, 5-cell receiver pack and a wall charger.
Features
- Duratrax 2-channel FTR 2.4GHz radio system with digital steering servo, 5-cell, 1300mAh receiver pack and 110V wall charger
- SuperTigre G-27CX .27 engine, with recoil starter, polished tuned pipe, glow plug and 3-year limited warranty.
- Countersunk, hard-anodized 3.25mm aluminum chassis
- Grey-anodized aluminum parts include threaded Big Bore shocks, drag link plate, front and rear shock towers and front hinge pin plate
- Hardened steel driveshaft and gears
- 3.5 mm shock shafts
- 4 mm shock towers
- 4.5 mm tie-rod turnbuckles
- 5 mm camber turnbuckles
- Droop screws front and rear
- Installed front and rear sway bars
- Hex head hardware throughout
- Fuel tank with a race-inspired “ring-pull” lid
- A high-downforce wing
- Mounted racing tires with foam inserts and 17 mm hex hubs
- Body in four sizzling trim schemes
Source: Duratrax [duratrax.com]
More...
1 - 1 of 1 Posts
