I started on the driver stations this week and here's how they will turn out. Though I only got this one done and only lane 1 wired so far I only need to connect the remaining 3.
I started by boring twelve holes with a spade bit but I didn't go all the way through as this will help to show off the wire colors better.
I then added the rebar tie wire for the posts. Six go through the top and six from the bottom.
These rebar tie wires will be bent up out of the way, I'll attach a butt connector to the end then run wire from it to the terminal strip.
Note: The rebar wire is 1/16 so a 22-18 gauge connector is a perfect fit.
The end results, all four controllers ports will be live so any lane can be run from any station.
The last thing to do is to stencil the lane numbers to each port.
