1 - 1 of 1 Posts
*Click the image for more information
Brand new hop ups for HPI FORMULA TEN from Yeah Racing - (#F10-013OR) Aluminum Motor Mount Single Piece, (#F10-024OR) Aluminum Body Post Set and (#F10-039OR) Aluminum Servo Arm have just arrived yeahracing.com. Please also consider the other new released hop ups for F10 - - (#F10-042OR) Aluminum Steering Arm, (#F10-014OR) Aluminum Rear Main Drive Shaft, (#F10-006OR) Aluminum Knuckle Arm and (#F10-142) FRP T Bar.
Aluminum Body Post Set (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Body Post Set (OR) for HPI Formula Ten.
# Great upgrade for the standard plastic parts or to replace broken parts
# Less flexing than standard parts
# Made of high quality aluminum
# Long lasting & durable
# Make your car looks stunning
# Easy to fit, straight forward replacement
Feature:
# For: HPI Formula Ten
# Material: Aluminum
# Color: Orange
Aluminum Servo Arm (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Servo Arm (OR) for HPI Formula Ten.
Feature:
# Color: Orange
Aluminum Motor Mount Single Piece (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Motor Mount Single Piece (OR) for HPI Formula Ten.
Feature:
# Color: Orange
Yeah Racing Aluminum Rear Main Drive Shaft (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Rear Main Drive Shaft (OR) for HPI Formula Ten.
Feature:
# Color: Orange
Yeah Racing Aluminum Steering Arm (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Steering Arm (OR) for HPI Formula Ten.
Feature:
# Color: Orange
Yeah Racing (#F10-006OR) Aluminum Knuckle Arm (OR) for HPI Formula Ten
Description:
# These are the Yeah Racing Aluminum Knuckle Arm (OR) for HPI Formula Ten.
Features:
# Color: Orange
Yeah Racing 1.6mm/1.4mm FRP T Bar (GN) for HPI Formula Ten
*FRP T Bar is available in 2 thickness
# 1.4mm FRP T Bar (GN) - (#F10-142-1.4)
# 1.6mm FRP T Bar (GN) - (#F10-142-1.6)
Description:
# Yeah Racing FRP T Bar, produced from high quality Fibre-reinforced Plastic this T-bar comes with ultra strength and flexibility, and can be twisted nicely to cope with the shock from racing. The item can highly improve the suspension system and obtain more grip, the light in weight will also improve the top speed running of the car.
Features:
# Material: FRP
# Color: Transparent Green
Source: Yeah Racing
Yeah Racing New Alum. Suspension Mount for TB-03, TRF416..
*Click the image to buy
Yeah Racing (#TB03-019) Aluminum Suspension Mount for Tamiya TB-03, TRF416, TB Evo 5 MS has just arrived @ rcMart.com. The suspension mount is available in different rate (1A, 1B, 1C, 1D, 1E, 1F, 1XC and 1XD - which indicated the Interval width between the centre ends of the suspension mount) for an advance toe angle adjustment of suspension arms. Please refer to the image below for more details:
*Click to enlarge the image
(image shows a part of the original tamiya TB-03 manual)
Description:
# This is the Yeah Racing Aluminium Suspension Mount for Tamiya TB-03, TRF416, TB Evo 5 MS.
# The Suspension Mount "rate" as same as Tamiya
Feature:
# For: Tamiya TB-03, TRF416, TB Evo 5 MS.
# Color: Blue
1 - 1 of 1 Posts
