61 - 80 of 83 Posts
Hello Mark, I'd like to ask, if you don't mind, are you useing transparent pearlescent or opaque pearlescent paints for the Aztec? And what brand?
I also wondered about when it comes to putting the decals down, don't you have to gloss first? Then matt/satin after that? What will this do to the Aztec effect? Wont everything then be the same sheen? This is something I just can't wrap my head around. Any clarification here sure would be appreciated!
hal9001-
Discussion Starter #62
hal9001-
Hey hal9001!
I'm not using pearlescents with this build just flats. I don't have the brands with me but I do know that you do NOT need a whole lot of them to make this job look spot on. In fact when the filming miniature was being done I remember them saying that they had 4 jars of these paints and barely half of each of these colors were used because they were thinned out and an extremely thin layer was used on each. I'll find the brand name I was looking at and post it they were not too unreasonable in cost as I recall.
For the decals, yes I will be adding a gloss coat to the paint finish, apply the decals then satin finish the final layer to seal the decals in. The gloss coat and satin coat will only enhance the look of the Aztec patterns so Iwill not worry about it doing anything to the paint job. The only parts I will not be adding the gloss coat to are the Strongback and the other darker detailed areas. If you look at ST:TMP especially the drydock sequence you'll see very little sheen on those areas. It will look very nice when finished.
Mark
Thanks Mark! Didn't realize you were not useing pearlescent paints. They have a unique sheen and that's what I was wondering about when the final clear coat was applied. Where there would be a difference between the pearls/Aztec and the base color sheen.
When I see pics of the filming model and ones others have built, I see a distinct sheen difference. That's what I was refering to and how they keept it distinct after the final coat.
Thanks for the info and don't worry about looking up the brand, I thought they were pearlescents.
hal9001-
Discussion Starter #64
hal9001-
:cool:No. No pearlescents this time. For these models I am just going to create an illusion of the pearlescents. Certain parts of the hulls will have the sheen to it while other parts such as the strongback and other darker details will remain flat. This is escpecially noticeable in the drydock sequence. Personally I don't believe that applying a gloss coat will have much effect on the pearlescent appearance. I have held off on the pearlescents for now so that I can observe others who have used these paints on their models to get an idea of how I want to persue using the pearlescents. However, even though some of these models are painted up real nice, I keep seeing same mistake with the Aztec patterns and that is they are just a little too pronounced for my taste. Mind you I'm not trying to put down anyone's efforts or bashing anyone work. Everyone has their own approach to building these models, including myself, but what I see on the screen in the movies is a lot more subtle and that's more of the look I'm going for at this point.
Also, as I recall, the pearlescents that I saw on line have a gloss finish to them anyway, so my thought was that using a highly thinned out gloss finish sprayed on very lightly would be enough to seal the decals in place. I did this with the flat paints I've been using on my current build and it seems to have worked out very well.
Thanks again, Mark
Discussion Starter #65 (Edited)
Updates For June 2012
I've added 15 new pics for the Enterprise Update.
For the Enterprises it has been quite a month of work. The first tough part was to add the new re-cast thruster pieces to the tops and bottoms of the saucers. Some were exact fits while others needed a bit of sanding and puttying, but all this effort will produce a very nice lighting effect later on. I've had to cut out some wiring holes in the saucer section to allow the wiring to go from the saucer to the Dorsal. I've also had to remove a section of one of the framing braces to allow room for the crew rec-deck assembly for later on. I have also opened up the rear of the upper saucer to allow for both the epoxying of the warp crystal/impulse engine piece as well as the lighting effects for that area. I've made the hole large enough so I can epoxy these pieces into place well enough so they won't move at all. To epoexy them into place and take care of the putty work at the same time, I line the entire rim of the Warp crystal piece with the putty, then press it into place, then I immediatly epoxy the piece into place with 5 minute epoxy. When this is set I take an exacto blade and remove the excess putty from the outside. This alows for sanding to be kept to a minimum. Next I mask off the Warp crystal dome as well as the impulse engines so that I can opaque the entire hull top and bottom. I let the Flat black set for at least a day then spray the entire top and bottom with Light Neutral Gray. I've been finding it better to start with the darker colors first, then mask off the smallest details and work my way up to the lightest colors. By next month I should have most of the first masking done and hopefully the second one for most of the saucer pieces. Hope you enjoy this update and I'll see you all next month.!
Mark
Discussion Starter #67 (Edited)
August Updates
This months update is very picture heavy!
For the Enterprise update, unfortunately I was not able to get too much accomplished on the Aztec Painting because of spending so much time on Reliant. But it has been started and is going good as well. Although the Aztec pattern is different from Reliant I am still using the same painting technique. First I've sprayed the entire saucer sections, top and bottom Neutral Gray and now I'm in the process of masking of smaller areas of the hull to create the first color of the Aztec pattern. These maskings will then be removed after spraying the next color "Light Gray" and then lightly spraying over that to soften up the harshness of the Neutral Gray color. Then for the final Aztec Pattern I will overlap different parts of the first color with the masking and painting to give the hull the appearance of several different shades of color in the Aztec pattern. There are 5 new pics of this process in the August updates. As of this update I have two of the Enterprise upper saucers masked and ready for painting. By the next update I should have all of the base colors finished.
See you next update! Enjoy! And as always comments and New members are always welcome!
Mark
Discussion Starter #68 (Edited)
Updates for September 2012
Hey everyone! There are 26 new pics for this month's update! Please check them out! Comments are always welcome.
It's been a very busy month for the Enterprsie models! I've now begun working on the Aztec patterns! And hooooweee! that is sure a lot of work.I've decided not to use any friskette to make the patterns because I've found that the widths of the grids vary slightly from one another. Some are wider and some are narrower. This can be very frustrating when using a friskette template. So in this case I measured the widest grid and use that for the basis of my pattern, then for the narrower grids I just make slight cuts and do some minor overlapping for the narrower grids. So all of the patterns for each individual grid are now matched up more perfectly with masking tape than they ever could be with a stencil or friskette. It takes about one hour to do one entire grid circle on each of the saucers. All of the upper saucers Aztec patterns are completed and I've got 4 rings of the grids done on the lower saucers. So, yeh, do the math... yes, about 30 hours to get what I did, done. But the pictures will speak for themselves. Everyhting is turning out very nice at this point.
I've also had to tweek a few things with the engineering hull and deflector housing. As I re-watched parts of ST:TPM and ST: TWOK I realized that something did not appear to be right and it turned out to be the Strongback and deflector dish housing. In ST:TMP when the Enterprise was in drydock, I was not seeing any of the strongback details that I painted on the ship that I was seeing in the movie. There was way too much definition to the colors that I had used and there is a slight sheen to the surface of the ship indicating she was basically "BRAND NEW". I began to rethink what I did and it turns out that I had been following pictures of the studio model details as the model was repainted for 1701 - "A". I became very distrought and realize this needed to be corrected befor I add decals. The solution was quite simple though, I took some light Neutral gray and thinned it out a lot. Then with a very light spray setting on my airbrush, I resprayed over the entire strongback with this color and guess what. It worked. You can still see the details but they have been toned down quite a bit. I will be spraying the Engineering hull as well as the other parts of the ship with gloss to give it just enough sheen to not only add the decals, but to give it the new hull look as well.
I should be able to have the rest of the masking done by the next update and hopefully all of the decals will be finished, then I can finally start putting these babies together and begin the lighting and wiring.
So, that's all for this update. I will see you again next update! Take care,
Mark
Mark, so the strongback in TMP isn't green-ish like I've seen on all these decals? I'm too lazy to pop in the DVD at the moment but will soon to see the grays in the SB. Well then, is the "A" strongback in blues or not?
I've tried to follow on the Aztec, but I lost my way trying to follow bread crumbs! I did find it interesting to see the way you laid down random light gray 'squares' before the actual Aztecing. But I also find it interesting that you're not useing pearlescent paints. I can't wait to see the effect you've come up with.
Decals next! You're getting close...er. Are these commision work? I guess this is kinda a dumb question, unless you 'need' three Enterprises.
This is getting darn interesting Mark. Keep up the good work.
hal9001-
Discussion Starter #70
hal9001-
Well, this could be quite the debate for many model builders, but I do believe I've read in one of the threads in this forum that the colors that were used by the original model builder were in face a sage green. There is one shot in ST:TWOK where I can actually tell the color is some sort of green and that's after Reliants attack on the Enterprise. The interesting thin though is that I can see it only on the dark area of the upper part of the dorsal where it connects to the saucer section. It is definately a grayish green color. It's a little more difficult to see the strongback colors, though, mainly because of the lighting of the miniature. Just before the end of ST:TMP you get to see that great beauty pass of the Enterprise from underneath. You can see the details, but they appear to be a gray-ish color. There is also an underneath shot of the Enterprise in Wrath of Kahn when the Enterprise is trying to escape from Reliant before she blows up. This too appears gray... at least to me and on the screen. I'm sure there is a greenish color to them but because of the lighting on the miniature it appears to be some sort of gray so that is why I decided to just use a gray finish on the Strongback. but the one thing I can say without a doubt is that the current look of the strongback on the miniature was updated on the model because the ship was now NCC-1701-A for ST:TVH. Just slight changes to the miniature and you have a brand new ship. If you watch the drydock flly-by scene again and look at the strongback, there is no indication of multi-colored detailing. There are a few other scenes that show this to be true as well. But the decals are definately reflective of the 1701-A look. And they are Blue colors to answer your question. At least for me, though this gray look solves the problem.
The random squares are a way to solve a very difficult problem. For one thing I don't have the time at the moment to do the wonderful detailing work that was done on the original miniature. As it is I have been working on all 4 of these models for about 2 years now, but that is mainly due to the building of interior rooms for these models. Anyway, When I was building the Engines on these builds, I used about 4 different paints to give it the multi colored look, but wen I was finished I discovered that these colors where way too pronounced. So with the lightest color I was using I oversprayed all of these colors very lightly and it wound up giving what I considered to be the perfect look for these starships. Then when you add some gloss for the finish, it makes it look even more like some sort of metal. The idea of the Aztec look is that of different sheens in the metal used to build it. You can even see this look on some modern ships (Not the Aztec pattern specifically, but mis matched painted sections due to the different metal textures in the materials used to build the ships) The effect is realistic and allows for the look of a large scale. So when the random squares are masked off partially over and not over it will give the appearance that there was more work done than actually was for the Aztec look.
As for the Pearlescent paints, I do want to try using them eventualy but I really want to practice with them before I do anything with them. I've seen several builders use them and while their models look terrific they somehow appear too overdone. When I talked this point over with my client he agreed with me that the Aztec look should be very subtle. Like, it's there, but it isn't there. If you look at the Aztex work on my other build the Reliant, you'll see how using the different shades of gray and a gloss finish can work out almost as good as the Pearlescents. But as I said, the Pearlescents will be for a future build.
BTW I also seem to recall that for the 7' miniature that 4 jars of pearlescents were bought to paint this model and only about half of the jars of this paint were used overall, which means the paints were very thinned out and only enough of them were used to give only the Pearlescent EFFECT on the miniature paint job. That is Talent. The model is a beautiful piece and that along with the drydock represents everything that I got into model building for. It was totally worth the time and effort.
And finally (sorry about the long winded comment) these 4 models are comissioned builds. They are fun to do so keep watching, you may actually see them finished! Thanks for your comments.
Mark
Since am doing a TMP styl 1/350 Refit I need to chime in.
The Refits (TMP) definitely had a different strongback Aztec as compared to the Ent-A. And sorry to tell you NemVia your strongback pattern is that of the A not the Refit. On the A the lower forward section of the strongback Aztec goes in to some kind of broken up rectangle,
http://www.modelermagic.com/wordpress/wp-content/uploads/2009/09/KG_MD_PL_1701-A-002.jpg
While the Refits continues the interlocked >->-> shapes all the way to the front.
See here
and here
http://movies.trekcore.com/gallery/albums/tmp2/tmphd0325.jpg
Also, despite the light conditions, a slight green hue for the strongback is noticeable in both TMP pictures.
As far as I was able to determine the lower forward secondary hull Aztec as well as most of the deflector housing are still the original TMP colors on the Ent-A. You can tell by comparing the small details and Aztec pattern of the B&W TMP pictures to the Ent-A color pictures. For the lower section they match, at the upper there are some changes, caused by the strongback repaint following the "battle damage sticker" incident that forced ILM to repaint portions of the ship. I used the colors seen at the lower secondary hull to reverse engineer the TMP colors. In case you have not seen it in the other threat, my results for the secondary hull Aztec:
Not 100% accurate either, I agree, but without color pictures of the Studio model at the time of TMP no one can be 100% accurate.
Discussion Starter #73
See here
and here
I totaly agree with your comments Garbaron. The second pic you posted was the basic reference pic I used to paint all of my details on the strongback not thinking there would be a great difference in the movie versions of refit vs. 1701-A. The thing that convinced me was when I re-watched the drydock scene and saw that there were hardly any of those details that I painted on there that were that pronounced. My goal here was merely to tone it down some and the easiest way to correct this was to do the light overspray. I usually pride myself on catching small details, but this was a huge overlook on my part. The correction I made is satifactory to me, but I have always been aware of the slight differences in the SB Aztec patterns. The pics I've included here are just a few of the reference shots that I've been using and while you can see the colors around the dish housing and SB are much darker and less colored than the 1701-A paint job. You will also note that you can still see the different shapes of the details on these parts of the ship, but they are not jumping out at you like the original way I had painted them. I do agree with you also with the point that there is a green hue to these colors, but as you said until we see the original paint job there is no way to see this very clearly. Too bad. Eventualy in my future builds I will attempt to be even more accurate, possibly even going all out with the Pearlescent colors as the ship should have. Maybe when the BIG BOY Enterprise is fully developed that will be my ultimate masterpiecel. Who knows.....? That is certainly in the future! Thanks for your input!
Mark
Mark, you absolutely right, I agree with you 100%! Most custom Aztec you see on models are way over done. You should have to make an effort to even see the Aztec, and I'm talking pearlescents here. If you're viewing the ship, say at a 3/4 view, you shouldn't really be able to see all of the Aztec at once. As you walk around it the other parts become visible. Kinda like these "Gangsta" cars are painted, the ones that change colors viewed at different angles. I don't know if that's the best analogy, but I think you see my point.
I've seen pictures of the filming model shown at different angles that make my point, just wish I had one off hand. Anyway, I guess what I'm saying also is in order to see the pearlescent Aztec you really have to see the ambiant light reflecting off of it. Sure, if you walk up to the model you're gonna see it of course, but it really shows off when light strikes it just right, it shouldn't pop out at you. Then you get the proper effect. If you stand back and see all of the Aztec at once, then it's over done in my opinion.
I just hope when the time comes for me to build mine I can practice what I preach! I've yet to do any testing of my theory so it may not be as easy to get the effect as I think it is. I don't mean to say doing Aztec is easy, but I think the pearlescent paint should be farly easy to work with to get the desired result. That is, after lots and lots of tests!!!
Three things Aztec needs: subtlety, subtlety and subtlety.
hal9001-
Discussion Starter #75 (Edited)
Updates for October 2012
This month I've been concentrating on finishing up all of the major painting and/or Aztec patterns on the Enterprise Saucers. I have to say I am super Glad this is now pretty much behind me now. Just some minor touchups that need to be done, but most of these will be finished when the models are completely assembled. The next phase of these kits is the DECALS of both the upper and lower saucers as well as the engineering hulls. I was kind of taken aback with these kits when I finally realized that there are several decals that are not included with the decal page namely, the yellow areas for around the phaser turrets along with their Red outlines. I had to paint all of these on instead. I also had to paint on the Red stripes that go along the outside of the bridge area. But all of these colors are now painted on included the gray stripes where the dorsal meets the saucer and the gray stripe that encircles the bridge area back to the officer's lounge. The area around the windoes was painted Intermediate blue. After everything set, I then Gloss Coated all of the Painted areas with 2 coats to first seal all the paints so that it would be easier to handle the model pieces and also prepare the surface for the massive decaling that needed to be done. The upper and lower saucer and the engineering hulls all needed to be decaled. I believe when I counted up all the decals that needed to be applied and there were about 283 individual applications. Many of the single piece decals had to be cut as individuals, namely the ships name and registry numbers. The decal sheet has great graphics but the backing used is extremely thin and for some reason I needed to soak them a few minutes extra in order for it to seperate completely from the backing. But everything went on very smoothly. After the decals were added another light coat of gloss coat was then spritzed on and left to dry for about an hour, this will prevent the decals from sliding if the coat is too heavy. Then after another hour or so I put on the final coat and this sealed everything in place. There are 38 new pic in this months update.
Now I will be able to start on the interior lighting and adding the interior pieces to the model. I will first need to build some cradles to hold the models in place while I'm working on these areas. But the ships are finally going to be assembled during the next month. Even I'm looking forward to the update for next month! See you then!
Mark
Discussion Starter #76 (Edited)
November Updates Posted
Hey Everyone!
This month was not a good month for productivity, I ran into a very nasty problem with the Hanger Decks... All three of them actually. While they were in storage the very ends of the flight decks started to warp (no pun intended) upwards. I finally realized there was no chance of getting these pieces to fit into the model properly, so I was going to have to re-do all 3 flight deck pieces. Apparently the resin I used, which was supposed to be a very hard and durable resin, was not as hard and durable as was promised, So I had to cut off all of the flight deck pieces and use what I originally wanted to use in the first place but was afraid that the paint would not adhere to it very well, and that is pieces of window quality plexi-glass. I first had to trace the old piece shapes onto the plexi then cut them and reshape them until they fit perfect inside the models. Then I wanted to add some more detailing to the flight deck namely, more and clearer landing and take off lines along with parking position lines for the work bees. The best way to do this was to first mask off the areas where the chase lighting effects would go, then spray the entire top of the deck piece flat black to make sure no stray lighting would come through the deck. Then I sprayed the same entire pieces yellow so I could mask off the lines I wanted on the deck. I didn't want to do this the other way around because I was afraid the masks might peal off some of the deck paint. Anyway it was easier to cut small strips of masking tape and get all of the yellow lines nice and straight. Then I sprayed the flight deck Intermediate Blue. Then removed all of the masks and finally sprayed the entire deck pieces with gloss cote. This gives the deck a nice sheen to it. Check out the pics in the November update page and you'll see what I mean.
After this huge delay I started adding the porthole glass which for the most part is .005" clear styrene #9005 and then the exterior lighting and wiring for the secondary hull. This proved to be quite a challenge because the Engineering hull comes pre-assembled and if you have large hands, it can be quite cumbersome getting all of these LEDs in there. Plus there is the matter of getting all of the spot lights aimed properly, then carefully putting the hanger deck piece inside without bumping anything. I have several Lighting TEST pics in this update and from what I'm seeing it looks pretty good so far and I can move onto the Deflector Dish lighting and start on some of the saucer lighting.
Also in this update I've been able to add one of the botany decks inside the engineering hull. This deck will be lit with some EL lighting. I really like the effect this stuff does on a piece like this. It lights the deck up very evenly rather than the sharp light points that an LED gives off. It was also a challenge to get this deck into the hull. It can not be done assembled. I had to first put the lower half in first, then the top piece. They are both very tricky to get in there. The corners of the pieces had to be fed up into the dorsal (Thank goodned it was hallow otherwise I would've really been stuck) then slowly turned so that the pieces were parallel to each other then one more 90 deg turn to make them fit into thier final postion.
Just one more note: Because of the redoing of the flight deck pieces, I was only able to accomplish all of these updates on only one of the models, so I will need to repeat these on two more of the kits and portions of this on the Reliant model. I apologize for this mess up, but sometimes these things happen, but actually I'm kinda glad it did because I like how the flight decks look much better than I did before. Well that's it for this update. Please feel free to make comments! See you in 1 month!
Mark
Discussion Starter #77 (Edited)
Updates For January 2013
Hi Everyone! Sorry this update took so long to get uploaded. December was a very rough month for my secular work so very little was done on Enterprise x 3. I have 22 new pics in the Updates for January page
For Enterprise updates:
I needed to get all of the viewport glass in place as well as the wiring and lighting for some of the spot lights and the warp engines in place before I could put the Hanger and Botany deck pieces in place. So I added the clear pieces into the hull first. This included the Botany Deck Viewports.
I was then able to add the exterior lighting on the other two engineering hulls and get all of the spot lights aimed to their proper locations. There are 7 Spots on each of the hulls. To insert them and secure them in place as well as aim them took about 2 - 3 hours each. No easy task because of the limited amount of room to work in with each of these models. In the November update I was able to get the first model done, but I learned from that one what NOT to do on the other 2. With the polar Lights Enterprise you can work on one half of the hull at a time, then assemble the 2 halves together. With the DeBoers, the hull is already one piece so you have to try to get your hands into that limited space. So it is very time consuming.
I was also able to finally put the saucers back on so all of the ships are basically assembled. I also added all of the upper and lower saucer spot lights and they are all in place. I was able to get one of the saucer Interior lighting in place this month. I'm using some 4" fluorescent tubes that run off of ballasts and require 12v. to operate. I just have 2 more saucers to put the lighting into, but I do have a good pic of the lighting tests with these fluorescent mini lights on. There are also a couple pics with the warp engines on. By the next update I should have all of the lighting done in the saucers as well as the torpedo launcher effect and other lighting effects such as the impulse engine effect. I am looking forward to sealing up this ships and getting ready for the next phase of 2 of these builds.
That's all for this months update. We'll see you next month.
Mark
Discussion Starter #78 (Edited)
Updates For February 2013
Greetings!
For this month's update I've spent much of the time adding all of the clear plastic for all of the windows and viewports, plus I'm adding the interior lighting for the Officer's lounge which, by the way is turning out fabulous. There are some great pictures of this lighting in the UPDATES FOR FEBRUARY page. Check them out.
In other areas I have had to scratch build and paint all of the interiors for the open hatch version of the Enterprise that will be in the Drydock. I wanted these hatches to be able to open and close, unlike the ones I made for the PLE version which always stayed open. I was originally going to make all of the hardware out of copper plating and tubing, but the problem I ran into was how to connect the hardware to the hatch doors without it looking like it was cemented together. I decided to scrap that idea and use styrene parts instead of copper so there would be less mess. It worked out better this way. I have 14 new pics in this month's updates.
For the next update I will be adding some updates for the plans for my new Drydock Builds. I've started blueprints for this build so that I can get the proper scale of this build to match up with the DeBoers Scale Enterprise. I'm estimating the length of this new version to be about 56". This larger scale will be good for adding even more details for this build. That and the fact that I was able to see the original Filming Miniature in person and I will be able to work off of that model to make some corrections and changes so that these models will be even more accurate to ST:TMP filming miniature.
That's it for now. Check out the pics, let me know what you think and I'll see you next month.
Mark
http://www.NemVia.net
Discussion Starter #79
I know it's been a long time since I've added to this topic, but I've finally have something to update on this build....
FEBRUARY UPDATES - 2020
I've finally put together another video of my Enterprise in Drydock. It took several tries and several reshoots of certain scenes, but it's all together now. This is my version of the flyby scene in ST:TMP minus the dialog and intercuts with the travel pod. I had to extend some of the shots to fill in those gaps. I could insert the scenes to combine my footage with the movie, but the video is primarily about the Drydock model. Also because of the size of my video shooting equipment I added a different of the shot by filming it from a different angle. I also had to match the scenes to specific parts of the musical score.
This is my personal homage to one of the greatest filming miniatures ever made for the big screen: The Star Trek: The Motion Picture Drydock and of coarse the DeBoers Refit Enterprise model. To make this video, I tried to match as many of the same camera angles that were the movie as possible. There's no dialog except for a little treat at the end to finish the video clip off with.
The flyby video was filmed using a JVS Everio HD camcorder and was mounted on a Andoer camera dolly track system. The video was edited together using Wondershare Filmora9 editing system. Some of the shots where accomplished by mounting a selfie-stick to the camera dolly to get into the more cramped areas of the dock. Most everything was shot against a black velvet background, except for the long shots. I just didn't have enough velvet material to do this. I just had to hide the source lighting out of camera view and film with the room totally dark, except for the models own lighting. The long shots didn't come out as clear as I wanted, but as we zoom into the model for the closer shots, the details become very clear. I would have loved to add all of the work bees, travel pods and space walkers into the shots, but that will have to wait for some time in the future when I have the ability and time to do all of that. This was never meant to be the high quality Cinemamatic version of this now famous scene in the movie, but rather a way to show off the model. I hope you enjoy the video. Sorry about the long intro, but I needed something to fill in the beginning. Jerry Goldsmith's theme just has to be played in it's entirety. Also ear-buds or headphones are recomended for an awesome viewing experience. (click the youtube link below)
Likes and comments are welcome.
Mark
http://www.NemVia.org
61 - 80 of 83 Posts
