41 - 60 of 83 Posts
Discussion Starter #41 (Edited)
Nacell Update
Too cool Mark!:thumbsup::cool:
-Jim
Thanks Jim!
What a month this has been! A lot of problems encountered with these builds, but eventually they were smoothed out and fixed. I've added a couple of pics for the Enterprise this month. I have to tell you it's been a tough month though. First I had problems with an order of 3mm yellow LEDs that I needed for the thruster effects. They kept sending me the wrong size and the wrong color LED which was becoming a problem and putting me seriously behind on my updating. Next I had one of the lighting circuits go out on me and it was difficult to isolate the problem, but I managed to finally find out what was going wrong with it an repaired that with no problem. I also managed to break 2 of the fluorescent tubes that light the warp engines..... GAAAAAH! Now I'm in the process of epoxying the engine halves together which is no easy task because of the nature of the epoxy and it's curing time. At first I tried to epoxy the entire engine pieces together in one shot, but found this to be way too messy and cumbersome and it left a few gaps I didn't count on. So in order to avoid the mess I decided to epoxy only small sections at a time. First, I'm epoxying the fron't and rear of the nacell then clamping those together over night to ensure agood bond. Then with 2 exacto blades I apply the epoxy to the top seam only. I use one knife to hold the seam apart then apply the epoxy with the other knife, clamp it together and let it bond over night. I repeat the same with the bottom seam. This allows me to avoid a lot of mess by doing it a little at a time. The pictures I've added show that I've used an abundance of epoxy to make sure the seam is over-filled. This will minimize the need for a whole lot of putty later on. But at least now I have the Warp nacells assembled. I will begin smoothing these out and preparing them for opaquing and their final paint job.
I really should have gone over the assembly instructions a little slower. It does say very clearly that this is not a model to be rushed or assembled in one night. Not that I've been trying to go that route, but I would have thought maybe just that tiny iota molecule sized bit of "faster" progress would help just a wee bit. Sometimes you have to step back and tack a breather or two to collect your thoughts and strength to re-group and get back into it again.... which I have.... Feel much bettrer now that I've solved a few problems.
The real problem with these kits is there are no guide tabs to line up the pieces so you have to be very careful when assembling this type of kit. I've read in other forums about those who have built these models and have had the same reaction as to the dificulty level. Some of the pieces don't line up exactly so there is some improvising to be done. I'm not complaining... Just venting. I myself can't wait to see them finished that's why I keep plugging along. Any thoughts on this are welcome. I should be ready to start putty work and a lot of sanding by the next update, then I can start opaqueing and final painting on these warp nacell pieces. See you soon!
Mark.
http://www.NemVia.net
Mark you are really outdoing yourself!
It is truly looking good!
Hey don't forget me if ya happen to have a spare one laying around!;)
That scene is on the extended video release of the movie....scaffolds and all!
Yes, and don't forget the stagehands too!:freak:
-Jim
Discussion Starter #44
Yes, That is one scene I wished they would have finished just to finish it for the DVD like George did with The Clone Wars, Even if they didn'e put it in the movie just to have it in the Deleted scenes would have been awesome.
Mark
Discussion Starter #45
WARP NACELL UPDATE FOR - 06/11/11
It's been a crazy month for the Reliant and Enterprise. The Nacells are quite a job to get just right. The problem is with the seams on the top and bottom of the nacell. They do not join together in a nice straight and even seam unlike an injection molded kit. I've had to do a lot of sanding on almost all of the engine pieces. Remember that there are 8 engines total for 4 models, so it's a lot of work. I've only been able to opaque 3 of the engines so far and am still working on the final sanding for the other 5 engines. I do have 4 pics in the Enterprise Album, #'s 129-132 and 3 new pics in Reliant #'s 34-36.
As I've stated in my last updates, there is a problem with the grills on all of the models. The filming miniature has 5 lines of lighting effects on the warp grills whereas the DeBoers only has 4. The Polar Lights model has 5 grooves rather than 4. To me this is a huge mistake that would take a monumental amount of work to fix the problem so I'll just have to allow for the difference. Also, the pictures I have of the Warp grills show that the lighting effect only goes back so far on the engines and not all the way to the end of the grills. There is a little bit of difference in opinion as to which part of the grill actually lights up. I'm sticking with the deep grooves since it matches up with the movies stills I have. It's too bad this error is so obvious, at least to me. But what can I do. It will still look sharp when they are finished.
By my next update I should have the base colors started on the engines. See you then!
Mark.
Discussion Starter #46
Warp Nacell Update for 07/31/11
I Apologize for not posting anything for a while, but let me assure I have been extremely busy on these ships. As of now I am working on the most difficult part of building these models and that's the starting of the AZTEC Pattern for the Engines. In the DEBOERS ENTERPRISE update I've sprayed the basecoating of FLAT WHITE on all of the endines and pylons, then I began with the first of up to 5 different colors I will be using for the AZTEC patterns. I have also started on the basic "Lightning bolt pattern" for the support pylons as well as the masking off of the first color that will be needed for the complicated shading of the engines and so forth. It takes about 3 hours per engine just to start this pattern off. To date I've completed the masking of all of the Port Side engines on the Enterprise models. Now I will be doing the reverse pattern on all of the starboard engines. I had a tough time deciding on what exact pattern would be for the pylons because even though there are many great pics of the filming miniature's details around many different parts of the ship, there are very few clear ones of the support pylons. So I had to scour the movies again, finally finding a good or at least a half way decent shot while the Enterprise is in Drydock. (Thank gooness for ST:TMP) The shot is about 3-4 seconds long but it showed enough of what I needed to get started. There are 5 new pics in this album #'s 133-138.
Mark
Discussion Starter #47 (Edited)
It's not possible to be disappointed with your work!:thumbsup:
Thank you! Hope you like what's coming up!
:cool:
Well, this month has sure been a productive one! I've spent the last 30 days or more doing nothing but masking and painting the Aztec patterns on the Warp Nacells and support pylons of the (3) Enterprise models. I've put 4 different colors on each of the engines so there were three different maskings that needed to be done. After all four colors were finished I had to removethe masks which takes about an hour and a half per side. There are 6 of these engines, so I will be doing this a little at a time over the next week or so. I will need to do some minor touch-ups to these engines, fix a few cracks and chips in the seams and paint, then I can finish all the flush vents, intakes, control thrusters and other parts that need detailing and paint. I will also be adding some small domes for the strobes on the top rears of the engines. Then I can add the decals that go on the back ends of the nacells. All around, the paint jobs are turnng out well. Please feel free to leave feedback and let me know what you think!
After the engines are finished I will begin work on the engineering hulls which I think will be a lot easier than the engines and there are only 3 that I need to finish rather than 6. See you next update!
Mark
Discussion Starter #48 (Edited)
:cool:
In this update, I've added 15 new pics to the Enterprise album. It took about 2 weeks to mask off all of the engines for the detailing work. I've added 3 new colors as you will see, plus I did touch-up work on the warp nacell grills. I think the pics turned put good. Next I'll have to paint the front nacell grills copper, the inside stripe on the pylons will have 2 more shades of gray added to finish off that detail. There is some putty work that needs to be done on the basses of the pylons then I will put a very thinned out off-white color over the Aztec pattern to tone it down just slightly. It will look sharp when it's finished. Then I can add the decals to the rear of the engines. I've made my home page so that you can access the DeBoers Enterprise project from the side bar on the left. The new pics are on page 3 pics 149-163. Let me know what you think!
Mark
What can I say that has not been already said!:thumbsup:
When do you find the time to do this?:freak:
Absolutley flippin awesome!
-Jim
Discussion Starter #51 (Edited)
Warp Nacell paint job Completed!!!
That's a lot of masking but... Wow!
:freak::freak::freak::freak:
Yep! All I see are strips of blue in my sleep!
Big update this month! I have added 16 new pics to the Enterprise album! A lot of energy and work have gone into these engines and I'm happy to say that other than a few pieces that will be added later on, the Engines are all basically done!
In the Enterprise update, I've had to spray the entire engines with a very light and thinned out coat of off white. This will tone down the Aztec colors just a little bit but will allow the sublte shapes of the Aztecing to show through. I've also painted up all of the misc. details such as the inside stripes that run up the support pylons. This took 3 different colors to make the stripe look perfect, Then I've added the decals which in this case are only 2 decals to the rear of the engines. The only thing I need to add to these now are the small domes for the warp crystals and the strobes on the rear ends of engines. So now I can finally put these in mothballs for a while and start working on the next part of this project, which I'm looking forward to, and that will be the "Engineering Hull". At least in this case there are only 3 pieces to work on, so the updates might be a little closer together.The new pics are on page 3 of the Enterprise album pics 164 - 179.
See you next update!!!!
Mark
Discussion Starter #52 (Edited)
Last update for this year...
Well, everyone! This has been a busy year for me. The projects are coming along nicely and I feel I'm gaining some momentem. Unfortunately because of my peak season which will be starting sometime this week, I'm afraid I won't have much time or energy or the will to do much on these projects for the next two weeks or so. However, I've been able to get a lot of things accomplished since the last update. Noteably:
In the Enterprise build: I've added 26 new pics starting on page 3 slide 180 thru page 4 slide 205. I've begun working on the engineering hull. Like the warp engines there is a ton of putty and sanding work that needs to be done and redone. The bottoms of the hulls are the worst parts. They have a little bit of a valley in them which makes it very difficult for a nice smooth and rounded finish. I've had to fill in the old mounting holes on the 2 shipd that will be mounted from the saucer section in the drydocks and the other ship needed a larger bore hole for the mounting rod that will be used for the Mutara Nebula diorama. I have also added some new nacell mounting holes for when the engines are finally attached to the hull. I'm also going to add the lighting effects that are seen on wither side of the travel pod docking ports. To do this I had to drill out the old hatch doors and have rebuilt my own doors so that I can re-cast them in clear resin to allow for the small but interesting lighting effect.
Recasting a LOT of parts. This model was not inteded for lighting that is for sure. That is why all of the port holes need to be drilled out. But also, there are other pieces that need to be redone. So far I've recast the torpedo launching tubes, the lighting housing for underneath the fantail, the strobe light covers or domes for the flashing light effects, the airlock piece which I built at the begining of this project and have now finally got around to casting it into a single piece. I only need two of these pieces, that's why it took so long to get to. And finally the largest piece I've had to cast: the main deflector dish and the dish housing. This too was originally to be done as two seperate pieces, but I didn't like the way the hole drilling was turning out and I do not want it to look like a drilled them out either. So I recast these two pieces into one clear resin piece. I will then follow a technique that was used while building the Spacedock in STIII:TSFS where the entire plexiglass model was first painted over and then all of the spots that were supposed to be windows or portholes where lightly scratched off to allow the interior lighting to come through. I tried this on a scrap piece and it works out beautifully. I will have pics of this later on.
I just have a few more small things to add onto the engineering hull by way of detailing and then I will be ready to begin the painting which I am looking forward to doing.
Well, that's it for this update. Please be safe everyone. I will see you in 2012!
Take care, Mark
Discussion Starter #53 (Edited)
Updates For January 2012
:cool:
As mentioned in my last update I have updated some of the features on my site to help make it easier for Members and Visitors to find my latest updates without having to search though too many photos. Starting this month, you will be able to go directly to the current updates by clicking on the UPDATES FOR JANUARY 2012 page on the left hand sidebar. I will probably leave 2 or 3 months worth on the homepage and then move them to the appropriate pages later on.
Also thanks to everyone who has visited my site. Last month My 100th member joined in. Don't be afraid to join up! More are always welcome!
Now for my first update this year, I've been doing some refining of the details on the secondary hull. I've added all of the re castings of the Travel Pod Doors and epoxied them in place, next the will be prepaired for opaqueing and painting. I've also started working on how to put the lenses on some of the lighting effects. In this case it will be the Lighting ouside the Hanger bay. My solution was to drill the holes out, then add clear resin into the cavities. Not a very easy process, but after the work is done it looks pretty sharp. I've taken a couple of pics to show what the lighting effects will turn out like in the secondary hull. The same goes true for the Thrusters. I've decided to cut out the wedges on the tops and bottoms of the saucers and re-insert them with clear epoxy resin pieces. Right now I'm still making the molds for these parts and I should have the first of them done in a few weeks. In the meantime, I've also been casting several clear and white resin shuttle craft that I will be using for the hangers and also the Drydock model for when I start on that project. So stay tuned. I will be opaquing the secondary hull in the up-coming weeks and then I can start on the Aztecing for the Secondary Hull.
See you next month.
Mark
Discussion Starter #54 (Edited)
Updates For February
:cool:
I have 16 new pics in the February update. I have spent a lot of the last month trying to smooth out the Engineering Hull. Ive been re-shaping a lot of the viewports and adding places for new lighting effects both to the Travel Pod Air-lock doors as well as the Hanger Deck. All of this is done in preparation for the Aztec patterns that will soon be added. To help protect some of the etched lines in the hull as welll as add some detailing I have begum masking out all of these lines and details. This process takes about 2-1/2 hrs per side. The pics in this months update show all of the detailed masking. I will then begin adding different shapes to different parts of the hull to begin some of the Aztec work.
Other updates this month include the spraying of the Main Deflector dish and housing piece which will also have some Aztecing put into it. Also I've sprayed the Bridge pieces in preparation for their detailing work. By the next update I hope to have at last 2 more color shades added to these pieces. See you in next months update.
Mark
Discussion Starter #56 (Edited)
Always good to hear updates from you Mark.:)
Thank you. :thumbsup:
-Jim
Thanks Jim! Glad you're keeping up! (LOL)
Update for March 2012 - 17 new pics!
Greetings everyone! Well, it's now March. Time is flying by quickly! This past month I've been working on the masking for the 4 different shades of Aztec paneling for the entire Engineering Hull. So far I've been able to do the first 3 shades and 2 seperate masks. I was able to spray the 3rd shade on this morning. After the paint has set for 24 hrs I can begin the masking for the final shade on the hull and do some minor masking for the Strongback features as well as the housing for the main deflector dish and the dorsals front and back. On a few parts of the hull, some of the small masks have come off or have moved a bit due to the handling and from what I'm seeing the painting is turning out very well. Unfortunately we won't get to see what it all culminates to until the final colors have been added, the paneling is toned down and then the masking can all be removed. I've also begun some more masking for the main deflector dish piece (that is not connected to the engineering hull). The Deflector housing and stronback will be done in slightly darker colors, but they will not stand out too much. I'm really trying to shoot for the look in ST:TMP where everything is more subtle. From WOK onward there have been different and duller finishes added to the miniature for filming purposes. After the painting is all finished for the Engineering Hull I can finally add the Nacells to the hull and start working on some of the wiring and lighting. I feel real good about how things are looking so far and even I am looking forward to my own future updates. It's getting there my fellow modelers. Just hang in there! To view the pics go to my site below!
See you next update,
Mark
Discussion Starter #57 (Edited)
Updates For April 2012
This has been an extremely busy month. All of my work has centered on the Secondary Hull and the Strongback detailing. There are 4 different colors added to the Aztec pattern on the engineering section and then they were oversprayed with the final off-white color that will be the ships signature look. The Strong back was a little different though. I used about 6 shades on this part as well as the deflector dish housing. Although the final colors are not on these parts, the Secondary hull is now completely Aztec-ed. There are 26 new pics in the Updates For April page on my website. I mounted the engines on the hull as well as the saucer to get an idea of how everything will look together. Check out the pics and let me know what you think. I will be finishing up the Strong back as well as the front part of the Deflector dish for next month's update. I will start assembling the Hanger deck, the botany Deck and some of the wiring for the engines. I will also finally begin to work on the Saucer section. So stay tuned and I will see you next month!
Mark
Discussion Starter #59 (Edited)
Updates For May 2012
For the Enterprise update this month, I have been able to finish up most of the work on the strongback and the deflector dish detailing. I still need to scrape off some of the paint on the outside ring of the dish to allow for the lighting effects, but for the most part the painting is finished. I will now start decals on the engineering hull. There are only a few to worry about. I should have an update for this by next month. For this month I have started doing the prep - work for the saucer sections. The first thing I needed to do is to make sure all of the viewports are nice and even, then cut out all of the thruster pieces and replace them with clear re-cast pieces so the lighting effect will look half way decent. I will also be adding the bottom saucer domes. I've cut out all of the holes for the lighting effect and will replace them with some clear pieces. I will be adding the bridge pieces to all of the saucer top halves at this point as well as adding the warp crystal domes on the back end of the saucer. All of this is in preparation for the Aztec pattern to be added on the top and bottom halves of the saucers. The latest pics are now availible in the "Updates for May 2012" page.
Mark.
41 - 60 of 83 Posts
