Is there a technique to cutting down pickup shoe springs? The unmodified springs have a flat area on both ends. What I mean by that is the spring will stand on either end because the last coil or two are compressed together.
If I were to cut a spring in half, one side would still have the flat area, but the end where I cut would not. This cut down spring would not be able to stand on the end that I cut. Somehow, the coils on this end would need to be bent to create that flat area.
I don't know if I explained this well enough to be understood, but if you look at a spring, you'll see what I mean.
Thanks...Joe
Thanks...Joe
