1 - 1 of 1 Posts
CRC have entered the battery market with their new Maxxcell line of LiPo racing batteries. Featuring a low profile terminal design, convenient 4mm bullet tubes (photo shows prototype), low internal resistance (IR), high average discharge voltage and long run time, the Maxxcell LiPo is a proven winner. The 50C peak discharge rates deliver the punch, while a true 5200mAh delivers the run time. The 4mm tubes and bullet connectors closely replicate the solder tabs most every racer has used for years. Wired batteries with connectors are inconvenient and difficult to use as each manufacturer uses different placement, wire lengths and connectors, plus space is tight in most 1:12th road racers, all that wire and connector bulk takes up valuable room. With the bullet connectors, the wiring is much cleaner, efficient and lightweight. The pack is ROAR legal and is built to fall within the rules of IFMAR, EFRA, BRCA and ROAR.
Source: CRC [teamcrc.com]
</img>
</img>
More...
1 - 1 of 1 Posts
