Hi, I have a Craftsman blower model 358798980 which is built by Poulan.
Couple of weeks ago it quit running on high speed. As I had noticed that the carb diaphragm was leaking I decided to rebuild the carb. After finding that a new carb was just slightly higher than a kit I opted for that. I also replaced all the fuel lines(correctly routed.) New primer bulb and new spark plug. (RCJ8Y) what manual called for. All happy with what I had done, yank the cord, starts right up,same problem , runs while choked but take it off choke and it dies at full throttle. Okay, after a little web research I see that these are prone to the cylinder bolts coming loose, check that, all tight. I now do a compression check, 95 pounds, fine, right? The only part not replaced was the gasket under the carb as one was not supplied, old one seemed intact. The primer bulb is staying full of fuel when it is running also. Any ideas at all greatly appreciated. The wife swears that I will throw it in the trash and buy a new one so I wanna prove her wrong, please help a brother out.
P.S. Also has fresh 40:1 fuel
