I have an old Craftsman leaf blower that I'm trying to bring back to life. When I prime it fuel does come up into the carb (Zama) in the small line and into the primer bulb, but I also get fuel going into the larger line that returns to the tank. Is that normal or is there a problem in the carb? Any help would be greatly appreciated!!
That is what it is supposed to do. Before you invest a lot of time and money check the compression, if you have less than 100lbs it is probably shot, remove the muffler and check the piston and cylinder walls for scores and scratches. Have a good one. Geo
