Craftsman 4.5HP Yard Vaccum Sears Engine #143.014500 (Tecumseh) .
Runs OK but alot of oil going in air cleaner .
Things to look for ?
Thank You.
check the crankcase breather for blockage and check the breather tube also. make sure the dipstick is sealing properly. if its not one of those it could be a valve issue.
Thank You -- I will check breather and tube and Dipstick and so on in the morning .
Is CC breather a check valve one way like a auto PCV value ?
Valve issue would this be a guide or seal ?
