All this rain we've had allowed me to catch up and finish a couple of things.
This is an Aurora Hot Rod coupe that was in very bad shape. I painted it and added a some die-cast bits. The engine is out of a RC2 die-cast Ford. I fitted it in and cut the hood open to clear the air cleaner. The front disc rotors are cut down T-Jet wheels. The rear bumper, side pipes and front wheel/tyres are JL. The rear wheels are cut down dollar store DC's. The front grille is Maisto. It's powered by an Aurora 4-gear Magnatraction specialty chassis. I planned to put on front calipers and a steering linkage, but I figured I've done enough and I can move on to other unfinished projects. :)
Cheers
Discussion Starter · #8 ·
Hey there,
I see we have some Aurora Hot Rod admirer's out there.
Thank you very much for the comps'.
noddaz said:
That is really nice!
Do you run it at all?
Or are you worried about bits breaking off...
Scott
Noddaz- I do run it as I do all my cars. I've had bits come loose on some and just repair them. I don't race it-- just run it, so it doesn't happen too often.
I forgot to mention a couple of things I done--
The rear rims are stock specialty, but have been re-sized to fit the DC rims inside and the roof and windscreen have been chopped.
Here's a neat idea some of you might be able to use--I had several broken AFX Formula 1 bodies with missing spoilers and wings. Not really good for much- except the rear-view mirrors were still intact.
As on this car, they make great scale headlights. :)
Cheers!
