1 - 20 of 23 Posts
i think 162’ is a little big. although Ross aka rpm has measured it. i thought it was around 140’ but I may be wrong. either way the track is bag fast and a blast to drive on.
Discussion Starter · #12 ·
Your Right its 148 feet, my mistake.
Drive line is 148'
Center click track is 126'
Track total 40'X80'
So this is a 13.5 open timing with WGT tires what do you start the tires at and how long does a set last.
I am with the other guys no way it's 148 run line with less than 3 second laps.
We have about 155 and fast laps are 3.7s and most likely should be 3.6s
Jake
i start the tires at around 2.13 and this was the second weekend on them and they are still around 2.10. as far as the track size goes.. i havent rolled it im guessing the 110' to maybe 125' range is accurate.. i am going to roll it the next time i am there..
as far as the wire sleeving goes, here is a link i ordered the 1/8" and the 1/4" dont order the 1/8" its to small.. 1/4" is what you need..
http://www.frozencpu.com/cat/l1/g35/SleevingHeatshrink.html?id=7LrsavQF
1 - 20 of 23 Posts
