I have an older Kohler K321 on a Cub Cadet that has a coil that looks like one off an old Ford or Chrysler car. Will these coils off of a car work as a replacement for the Kohler (1 cyl.) ? Also are the condensers interchangable?
I've got my problem narrowed down to the coil, I hope!
Thanks, BJ
Yes, they will work they are basically the same, and you should be able to use the condenser as well, heck you don't even need a condenser to make it work, the points just won't last as long without one.
oscaryu1 said:
yeah they work basically the same, but if one's flywheel is bigger than the small engine it might not work, like 30 tech said use the condensers , the points last longer with them
Flywheel size does not matter, as this is a battery excited ignition coil.
This thread should also be in the General Discussion or 4 - Cycle area
