Front or rear
I had a rear arbor get stuck once
I built a puller using an old right side hub large screw/nut and a couple of long 4-40 screws---worked like a charm.
Discussion Starter · #4 ·
rear one, we tried wfreything but that lol ill try it tommarow i gotta race today so thanks for the help, also its the trackside truer, the dc one.
Nate if the shaft isn't bent or the bearings bad leave the arbor on and slip the arbor that you want to use in front of it, I have a trackside that has a 1/10 rear pan car arbor on it and I never remove it just mount your arbor in front and cut. btw did you ever make that edm body?
Discussion Starter · #6 ·
no i didnt make one yet, also the arbor wont move in either direction, its stuck so that the shaft is flush with the end of the arbor.
Discussion Starter · #7 ·
Got It Off!!, had to break out the puller and it came off :thumbsup: :thumbsup: :thumbsup: :D :roll: :roll: :tongue:
Spend a little time with that shaft and some 240 grit wet or dri sandpaper and smooth the gouges made by the grub screw and the arbors will slide on n off better.
