It's that time again...I am trying to get my 5 HP MTD Leaf Blower running and true to form, it will only run in half choke...As soon as I move it from full choke, it begin to shut down. This has become a yearly problem.
Is there any way to clean out the (PulsaJet) carb (I drained the gas from the tank at the end of last season)?
I have sprayed carb cleaner into the carb and tilted it to sit for awhile inside the carb...no luck.
It looks like quite a job to remove it from the engine and I am hoping to avoid this task. I am hoping that I don't have to take the fuel pump apart as well.
The linkages look pretty complex as well.
Details: B&S 5 Hp engine Model 137212
Type 1313 E1
Code 908917 YB
Help!
Thanks for any insight....
Sea Foam Solution
Will try your suggestion...seems like a good regular maintenance product for all lawn equipment...
I will post the result....
what I would do if you don't want to take the carb off, go ahead and do some seafoam, but right after that, replace the fuel pump diaphram, I am not sure how seafoam will effect that
