Found this a few weeks ago in an antique shop for just $5. It was complete except for the impulse engine part which is easy enough to scractcbuild. I Started assembly, I am building this pretty much out of the box with only aftermarket decals to replace the original 24 year old decal sheet in the kit.
One thing I am adding to the model is a stiff wire brace in the warp engine and pylons. I used clothes hanger wire inside of 1/8 inch styrene tubing. this will prevent the nacelle droop that tends to happen with this model.
The warp engines in place, very solid with no indication of twisting or flexing. I added two .010x .060 strips of styrene to the mounting tab of each pylon, this provides a very snug fit into the sockets molded into the secondary hull.
A close look at the added .010x .060 strips. these will prevent any chance of misalignment when installing the engines.
The only other thing I may do to this model is eliminate the molded in grid on the saucer.
