1 - 17 of 17 Posts
I'm speechless....wow.
I promise I will fall off my chair if you chrome up a 68 Barracuda, lose the hood and put a couple of nice black stripes down the middle with some meatballs on the side.
Keep them coming...they are awesome!
thank you. thank you. thank you.
H.
That looks NICE! Great work, and you chose the right car too! :lol: .
I guess I need to get on the ball and finish the modified 67 bird I am polishing up in order to "spectra flame" it. I finished the hood and engine and finished the first step on the body and base.
Porsche911gt3, I use heavy duty carburetor cleaner to strip the casting, but I suppose any paint solvent would work. I don't know if pine-sol works, but a friend of mine used to use oven cleaner on model cars. I use a Dremel tool and buffing attatchments with buffing compound. I polish in three steps. First, use tripoli compound, next white rouge and then jeweler's(red) rouge. The first step removes surface imperfections, the second and third steps produce a highly polished, shiny luster. I use felt wheels on smooth surfaces and cloth wheels on rough surfaces(like the base). It is a good idea to use separate wheels for different compounds and I prefer to clean the casting between steps(with rubbing alcohol, then dish soap and water and a toothbrush) to remove the compound before going on to the next step. If you get fingerprints on it, chrome polish works well to remove them. I have also heard that rubbing compound and elbow grease followed by chrome polish works too. Hope this helps. :wave:
1 - 17 of 17 Posts
