I was reading the CW's manual about what too do with a pushing car and one of the tips was to reduce the tension on the center spring. Can you explain to me why this would help?
It is a mis-type in the manual it should read...NewTooOval said:I was reading the CW's manual about what too do with a pushing car and one of the tips was to reduce the tension on the center spring. Can you explain to me why this would help?
It changes ride height, but it doesn't move weight....Erich Reichert said:One other note to keep in mind is that turning the collar in either direction doesn't actually increase tension it just moves weight/changes ride height.
Ya I must've been drinking a bit! LOL.bud3738 said:Wow....Until steve posted the correction I was sitting here reading this...I have been racing oval approx. 10 years.....And after drinking 5 beers...was thinking...Can I have
been screwing this all up for the last 7 years or so?.....thanks Steve...was about to
shoo myself in the groin.....Steves post is correct guys...
I'm not trying to start some sort of physics war here,Ralf said:Good point (about the scales) Eric, put your car on a set of scales, read the weight, then make a seriouus change to the center shock spring tension and THEN re-weigh the car. Ralf
By adding center preload you "transfer" weight to the nose, not "add" weight.Dan said:I'm not trying to start some sort of physics war here,
but this idea that changing your center shock setting, or the spring itself,
somehow adds or takes weight off the front, is just not sound.
You cannot change the weight of an end of a car, or of the side of a car,
unless you actually move something like the RX, or ESC, or your ballast...
Now... you can change the CORNER weights with changes in springs,
but never end or side weights.
This came up once before, I wish I knew where the post was,
for the sake of accuracy, I did three scenarios, two times each.
One was with a center shock spring, one without, and one with no side shocks. (iirc)
The rear weight was the same for all three examples, which it should be.
Anyone that has ever worked on real race cars, will tell you the same thing.
You cannot change front weight, or rear weight, by cranking springs.
If your scales indicate that you can, you need to get new scales.....![]()
I know your not Dan, it is possible for everyone to talk about this like normal peopleDan said:Now... you can change the CORNER weights with changes in springs,
Will try that tomorrow, didn't add the weights on each side but if I remember correctly both weights went up, one side more than the other. Ralfgezer2u said:Ralf- If you add the left front and the right front together, and the same for the rear, does it change the totals from the front to the back?
What I was trying to do, was make sure that others,Erich Reichert said:I know your not Dan, it is possible for everyone to talk about this like normal peopleMaybe theres a misunderstanding, we are talking about the same thing... corner weight. if you move collars it does "jack" weight to differnt wheels and that is what I was saying as you said above too.
