I received the muffler today from Tower. It was $9.99.
It is a bit smaller that I thought it would be.
As you can see in the picture, it is reversible. Meaning you can make it exhaust out either side. Neat idea I think. There is no baffle so if we decide we need one, it will have to be made. I figure no biggie. We might even find a washer that will work just fine.
Here are the pics, I will bolt it up to an engine and run it at the Rock in a couple of weeks.
Discussion Starter · #2 ·
Mounted on the engine and in the car.
I fired it up and it is a little different. It seems a bit louder and lower in tone than the HPI and the Associated. Using the same engine, set the exact same way, it sounds like it is restricted, just does not rev as free. We will see on the track.
