Hey Capt!
Yeah, I got a great start to this, then got tied up with work so couldn't get to it for a while. I'm hoping to be working on this regularly now, though.
This kit is not a resin kit, but I actually prefer working with resin kits over styrene. I like not having to worry about grinding through a thin wall of plastic when I'm doing conversion work.
As for drilling and pinning, I only do that if a kit has poor connecting points. Obviously, if parts meet up with only a flat surface you'll need to pin it. But if a kit has sufficient tabs and slots, I usually just use Zap-a-Gap to glue it then use epoxy putty to blend in any seams. If you are cautious about drilling, I would recommend using a dremel at low speed to help keep the drill bit from getting away from you and grinding away at the surface of the kit. Good luck!
Should have updates next week.
