[Okay, I got started on my Community Build project! Thanks for the invitation, MonsterModelMan! Here's the progress so far ---
Okay, get a cup of coffee and a cigarette and break the seal on the box.
That wasn't that hard. I think I'll have another cup of coffee and a cigarette. Okay, I'm back, let's take the kit out of the box and see what we have.
Nicely packaged.
And here's the Amazing Figure Modeler mini-magazine. There are supposed to be some tips in there from David Fisher. Maybe we should take a look at that. I think I'll need another cup of coffee. And a cigarette.
I guess the best place to start is trimming away any flashing that's on the kit.
And start the sub-assembly. I'm using Super Glue Loctite.
The reason I started with The Monster is that I understand that there is a fairly wide seam in his lap that will need some putty work done on it. I haven't used putty on a kit in decades. I'm using Testor's Contour Putty and the narrow tube spout allows me to get right up in the gap and fill it. Then using a cheap old brush I go over the putty with 91% alcohol. The alcohol smooths out the putty nicely and no sanding is needed.
While I'm sitting here I decide to go ahead and do the rest of the sub-assembly. The kit goes together fairly quickly.
There are a few seams that could use some putty and since the big seam went okay we take care of those right away. There were a couple on the bodies of both figures and one on each side of the Bride's head. I get that done and while I'm waiting for it to dry I remember that it's been a while since I had a cup of coffee and a cigarette. After the putty dries I take the sub-assembled parts outside and give them a primer coat of Krylon Plastic Fusion paint. I use black on everything except the Bride's head and body.
Now we need to let that paint dry and cure for a while so it's time for a cup of coffee and a cigarette. Talk to you later!
And, thanks again, MonsterModelMan! I hope I do a good job on this kit because I'm having a good time so far! This is the first time that I've used putty on a kit since the late 1980s and it wasn't the problem I expected it to be.
Nicely packaged.
