I have I think a toro s-200 I had my freind clean it. It only starts off primer after serval primes what could be the problem?
Chris, clean it again, after soaking in carb cleaner (or stabil) if you don,t have compressed air run a small wire thru all of the opening. There is something clogged.
jonsey
when cleaning your friend might of messed up the hi/lo idle speed needles tighten them in not to snug or you might damage the needle set then losen them 1 3/4 times each if you get it runnin just fine tune them till it idles
