I am not a huge modeler, but I do like 1960s kits of 1960s cars...
One of my favorite old kits is Revell's two-in-one Tony Nancy set. This is the Roadster... It's one of the best engineered old kits and the fit is still flawless once you get past the usual clean up. The instructions have you build the chassis, seat and body in halves around each other. I found you can build the whole chassis, fit the assembled seat in place, and also slip the completed body over the chassis. This makes painting and seam filling much much easier. The decals in the kit are not real accurate and are incomplete. I don't know how the original decals are, but these are missing the "Tony Nany" name on the back body (shown on box art) and some other white markings. Oddly white is on the decal sheet so its not like they saved money by skipping a color... Most of the painting was done with Tamiya spray cans.
AMT's Dragula built OOTB. This is a pretty simple, somewhat crude kit. I will build another one later and try to fix it up some. Much detail from the real car is missing (roll cage) or wrong (handles drawn on the side of the casket are flat), etc. The hard plastic wheels take some putty and sanding. Much of the chrome work should be gold not silver, too. Paint is Testors Gold lacquer spray paint.
The Revell Orange Crate reissue. I tried using Krylon Aluminum and Duplicolor Chrome on the chassis and engine with mixed results. The stuff rubs off and turns grey when you handle it. The wheels are the kit's own chrome. Still looks nice so far. This is a very tricky time consuming kit to build.
