I use this battery set up to power my track...
These are 6 volt batteries in series totaling 24 volts. The power is switchable from two
batteries, to three, to four. This gives me 12v, 18v, and 24v. I will also use this same
set to power my drag strip when I get it up and running. Yes, batteries gas when charging
or when they have a significant load on them. This is normal. If you have a bad battery,
or are over charging a good battery, this will cause excessive gassing, which can be dangerous.
I read on here somewhere where a guy was down the street from a car he was
charging the battery on. A cloud of sulfuric gas covered the neighborhood, and when he
lit his cigarette, the car exploded, starting a wildfire that burned up half the northwest...
so be careful. I don't know if I remembered that story right, but if you're charging batteries,
be sure to have the area well ventilated.... and stop smoking.
Anyways, I prefer the battery power.
