Can I??
977 Views 3 Replies 4 Participants Last post by  KenBajdek
can i use shoe glue on a grafite chassie? And get it off??
Yes, you can and it will come offf fairly easily with a small flatblade screwdriver as long as you keep it flat and don't pry up too fast!!!!! :tongue:
yeo it will.. whenever i have to add lead weight to my car i use shoe goo.. that way it doesnt ever fly off in a wrech.. i have used it on electronics in the past, but when u go to remove the stuff u usually crack the case...
I usually put a small piece of servo tape in the middle of whatever I'm holding down (esc, lead etc) then put a small amount of shoe goo around the edges. Not too much just a little dab on each corner. When you need to remove it just use your exacto knife to cut around the item. It will come off when you want to and it will stay there when you want it.
