21 - 40 of 124 Posts
So Bud are you going to order some now,and start an other Class for Bud Cars :thumbsup: ,We just got a paved oval to race on Thanks to T C Hobbies in Lee NH
CORO
sprintcars
hmmm im thinkin somone will hafta be making that conversion kit at this rate so everyone will have a car to put this body on :thumbsup:
I asked Bud about a conversion kit and he indicated you would have to do your own conversion.
Following the technique and method ZXBoy used you need:
+ Fun Wons 18 (typically too expensive to change an SC18 to a Fun Wons 18 because of different front suspension plate, tires, rear diff assembly, etc.)
+ Big Block Motor Plate set w/ Speed 300/Wattage 370/Big Block motor
+ BRP Pro top pod plate, shock assembly and mount
+ Narrowed extended battery tray
+ Larger front bumper design
+ 12th scale (Fun Wons tires) front foams front and rear
with fronts cut down.
ZXBoy intends on using brick cells because of their smaller width cross section. The radio gear and batteries have a much smaller area to occupy.
If you know someone racing 12th scale that doesn't glue up their own tires you may have a source for your front tires when they are done racing with them...
You'll just need to true them, so they are the same size, unless you need stagger.
Or cycle your rear tires to the front when they don't have the needed rollout height.
Lifetime Member
Bud: Let us know when those sprint car bodies come in.
Also, will you be running the mod class on oval or road course at da track after June 7th?
Discussion Starter #29
Here's some more pictures.............
The ofna brick cells all melted on me when I tried to charge them up ??
Oh Well....Never liked them much anyways when I was using them in my micro RS4. So I used 2/3 a's in a funky arrangement to fit 7 cells in there. Like putting 10 pounds of S#$%! in a 5 pound sneaker :freak:
I'll try and put it on a track this week and see how it goes......... :D
Wow! Thats looking good! I have bodies in but still have to make the wings hope to have all ready by next tuesday. I will also be setting up a sprinter for DA TRACK :D
ZXBOY
How was the sprint car,did the test go well.I just got my body and all I have to do is buid it.LOL Do you have anymore suggestion on building car.
Thanks
Coro
Discussion Starter #33
Hey Coro, The sprint car went good....... It seems a little over geared with the big block and the fun ones tires. I wish there was a bigger spur than the 52T........ I had a hard time fitting batteries, but I have the wheel base altered ( axle behind the motor and front plate moved back ). But if yours is unaltered should be a bunch easier.
Just make a new narrower battery tray to fit the body ( I made mine from thick lexan ) If you look close at the middle picture you can see the lower body mount is a cross wise tube secured with a allen screw on either side of the battery tray sides. drill the allen heads for a small body clip make a hole in the body and secure with the clips. The rear mount comes off the top of the damper rod.
The front tires were gripping a little to much in my test session and if I wasn't careful, it flipped just like a real sprint car, and the body and mounts held up very well...............
Bud I'm going on vacation for a few day, please save two bodies for me and I'll contact you when I get back. Thanks Roy
good news, good news...... Robinson Racing Products makes a 60T spur gear that we here in PA have been running for a while!!!! the part #RRP-1860 New Stealth Pro Spur. Works excellent, especially on a tight road course, in and out of the turns faster!!! Try it out and see what you think. :thumbsup: :devil:
Discussion Starter #35
Yeah,Yeah, That sounds like the hot set up for the big block and fun ones tires............Who sells them ??
Lifetime Member
zxboy: I ran 60/7 in my F.W. pro at buds track last weekend on the road course with the big block. It was a handful even at that gearing. Very easy to overdrive the turns, I tried some drag brake but it seemed to slow it down too much. On a small tight track turning the throttle ATV down seems to work good too. About 1/2 way through the 10 minute main I was wishing I could turn the boost back up though. But I'm barely coordinated enough to turn the wheel and squeeze the trigger let alone push buttons too!
I'm planning on building a sprint car this fall - I'll probably have a few dumb questions for you then. :hat:
Canbquick: We got SPRINT CAR bodies now !!
K1M:
we have one of our sprints ready, as soon as time permits I will get some photos posted. As a reference, we used 6 AA's, full size electronics (they were laying around), sc18 tires. We will have 3 ready for the last oval race at DA Track.
Lifetime Member
CanBquick and I have been busy working on our sprinters too! We'll have more pix later, but for now....
SC18 Sprint car radio plate:
