I just started building the John Long TOS communicator.
This is a licensed kit molded from one of the 10 original
communicators built for the show by prop artist Wah Chang.
The quality of the kit is excellent. All parts are as exact as can be after 40 years. The shells are Kydex plastic. I'm told the haircell pattern on modern kydex is slightly different from the Kydex from the '60s. The original Swarovski rhinestone jewels had 8 facets, Swarovski only makes 7 and 11 facet stones now. The kit comes with non Swarovski 8 facet stones that are not of less quality.
I forgot to take a photo of the antenna before I soldered on the frame.
The instructions say to attach the wire frame to the brass grid with safety wire to hold it in place while soldering with silver solder.
Next I have to solder the hinge discs to the assembled antenna grid.
