So this must mean they are legal?hankster said:
Not untill next year in 2005TOYMINATOR said:So this must mean they are legal?
Thanks fo clearing that up Almighty HANKSTER!!! :thumbsup:hankster said:These are basic rules that ROAR has setup as guidelines for brushless motors. They will be used in ROAR approved demonstration classes that tracks can run this year. In 2005 they will be able to be used in races for ROAR State, Regional and National championships.
Setting up "demo" class rules for a year has been normal for ROAR lately so they can test the concept of the new class and tweak rules before it becomes an "offical" class.
$50.00 for a cheep one!!!!!! :jest:FishRC said:I'd say that its more like the motors will get more technical to build and not less. But they will be harder to build as they require a more sophisticated method of building. Yes it will put a damper on the motor builders, time marches on. The cash cow of brushed motors is about to join the ranks of the 8-track. The days of seeing a mod motor for $50+ is nearing the end and with ROAR having started the clock on the change from brushed to brushless.
Thats the point. Seeing as a replacement brushless in only $80 and may last a year or even several years... Take that savings of time and $ and put it in other things that realy will improve your on track results.TOYMINATOR said:$50.00 for a cheep one!!!!!! :jest:
Motors with Sensors can be run with a sensorless esc,,,, The electric boat racers have already played with that.hankster said:The aim of the ROAR rules to to allow manufacturers to be mixed. Of course if you but a sensored motor you will have to use an ESC that can handle them.
