Picked up a Cadet push mower for $15. Said all it needed was a carb kit. Well he LIED!!! I cleaned the carb, replaced the primer. I have removed the head, lapped the valves. The exhaust valve was slightly tarnished. After lapping it had a nice clean surface. It will run but is hard to get it to start. It will barely run and pop at times, then it will run fine. Compression is 60-65psi. Can these over head valves be adjusted or is it more a ring issue.
Thanks
Model # 122602- 0203 E1
If you had the valves out, you had to take the rockers off. The adjustment is done with the nut that holds down the rocker. There should be a set screw inside the nut to lock it in place. Proper lash for you model is:
Intake: .004" Exhaust: .006"
30Year, I noticed that the intake valve has a valve seal under the valve spring, but the exhaust valve does not have one. Is there supposed to be one under the exhaust valve? I adjusted the lash and have about 80psi compression, but it is puffing out blue smoke. The cylinder walls look good. I did not see a valve seal for the exhaust valve on a parts diagram, so wondering if there is supposed to be one.
Thanks
