Hi Can anyone tell me the timing settings for a Briggs and Stratton lawn mower model 281704 Thanks :)
Timing? Timing is pretty much fixed for all aspects of these engines, are you looking for air gap settings perhaps?
Hi I am trying to time the crankshaft and valvie gear. When I timed the gears, the firing mechanism is at the bottom of the stoke of the piston. Where should the firing mechanism be? On top dead centre or ?????
when I time on the timing marks, the engine backfires though the carby.
Thanks John
There are timing marks on both the camshaft gear and the crankshaft gear, the marks should be lined up. Ignition is timed to the crankshaft and flywheel via the flywheel key.
