$$$$$$$$$$$$$$$$$$$My track might run a spec blinky mode class. I have always ran open classes so I would like to know whats best for spec 1 cell classes. ESC? Motors? High torque rotors? what aver I might need.
Thanks Sam
I heard the opposite. I hear the Novak Oval Spec 1s/Mamba set to blinky run well. The GTB2 w/x-drive is good also. The Hobbywing I also heard was good. It cost about the same as the GTB2 w/x-drive. Those 2 are as good but dont have the abilty to be run with dynamic timming at all. SO those 2 would be dedicated to Blinky only.I've heard of guys running 5 yr. old GTB's and beatin the big buck speedos.
+1ALL the blinky mode ESC's should be the same. Doesn't ROAR test them to make sure they are all zero timing? I dont run a class that runs them but have seen them all go fast.
I've put the old school GTB in the winner's circle at two BRL events, and on the podium just about every other time the car hit the track.I heard the opposite. I hear the Novak Oval Spec 1s/Mamba set to blinky run well. The GTB2 w/x-drive is good also. The Hobbywing I also heard was good. It cost about the same as the GTB2 w/x-drive. Those 2 are as good but dont have the abilty to be run with dynamic timming at all. SO those 2 would be dedicated to Blinky only.
Last year at the birds I tried the old GTB in 13.5 Spec. Aside from not ever trying this class I used my notes from 13.5 BM (before Mamba) where I was middle of the pack. Last year I was in the back of the pack.....I cant blame the ESC but I like to take those variables out of it. For local racing I would try it for awhile if you have one.
I was told the Mamba and Tekin in blinky had a bit more speed then the old school stuff. Now there are more choices.
I hoped to be wrong here but have never received a staight answer. I have a GTB....and want to run it in 13.5 spec at the birds this comming year. Now you claim to be the man here. Wins and top three finishes. So the GTB2 x-drive is no better than my old GTB in 13.5 spec.I've put the old school GTB in the winner's circle at two BRL events, and on the podium just about every other time the car hit the track.
As for wire size, that's somehting easily replaced, and the publicized on-resistance of any speedo is subject to a bit of fudging as well. Just like in the brushed motor days, there will be some minor differences, that may or may not actually impact on track performance.
Chuck did set a track record with a Novak with X drive hummmm lolI hoped to be wrong here but have never received a staight answer. I have a GTB....and want to run it in 13.5 spec at the birds this comming year. Now you claim to be the man here. Wins and top three finishes. So the GTB2 x-drive is no better than my old GTB in 13.5 spec.
Or are you talking 17.5 Sportsman truck. I ran that its first year at the birds and made the A main with a GTB. The 13.5 is a bit more diffacult class and it was pointed out to me as something that needed to be changed to run better. (By guys that were running much much better than me). Keep in mind when your running against guys like Allen Behler (spelling may be wrong) you had better be on it...every 10th counts big time.
Please someone help. I am not wanting to waste cash...but if its money well spent, I will spend it! I was leaning toward the Hobbywing or GTB2 (x-drive).
Tekin RS pro? Its high priced for the 0 timming class. I own (3) Mambas (2cell converted) I understand their software and programing. Of course the programing hasn't changed in over a year. (Maybe 2)Chuck did set a track record with a Novak with X drive hummmm lol
I put in a Tekin and went faster over a gtb 2.i know one thing I never have any problems with my Tekin .
Jake
Why thank you sir. Tekin RS pros run well in blinky mode.http://ovalrc.com/index.php?option=com_content&view=article&id=25&Itemid=185
13.5 spec....No novaks listed. I am sure they are fine but do not get to worked up on gotta have this or gotta have that
In that case it is easy...Hobbywing and no receiver packWhy thank you sir. Tekin RS pros run well in blinky mode.
But it seems the hobbywing would be fine.
Not so wraped up in what I HAVE to have.......more worried about what NOT to have.
